Re: Super M stuck in 4th or 5th
Posted by Nebraska Cowman on June 04, 2006 at 04:06:25 from (65.169.97.206):
In Reply to: Super M stuck in 4th or 5th posted by jaybird2 on June 03, 2006 at 21:03:21:
I'd jack up a wheeel, maybe try both wheels. Make sure it isn't something in the brake. But make absolutly sure the shifter rails are in neutral before you tear into it. and "bogs down like in 4th or 5th" ain't the same as stuck in 2 gears. Does it move at all? If it is 2 gears it will be locked up solid. Try shifting into all the gears. Chances are you will find one it is stuck in.
third party image
