Re: power steering for an M
Posted by Allan In NE on June 04, 2006 at 05:00:44 from (148.78.243.25):
In Reply to: power steering for an M posted by DJL on June 03, 2006 at 23:05:02:
DJ,
A new motor and priority valve will set you back $685 plus you'll have to find a bracket somewhere to mount the thing. Add the hoses and fittings and you're easily over $700 if you use new stuff.
I used all used pieces on my H including the pump and after the dust settled, it crowded $1100. :>(
Allan
