Re: Delco Remy
Posted by JMOR on March 11, 2009 at 05:06:25 from (76.187.218.177):
In Reply to: Delco Remy posted by Hugh MacKay on March 10, 2009 at 19:34:12:
Commentator said: (quoted from post at 07:38:00 03/11/09) That generator is indeed a 6 volt unit, used on several of the IH tractors (including Cub), perhaps additional applications. It is one of the year 1952 and later 6 volt units and is rated at least 20 amps output, so it was equipped with a voltage regulator. It is the so-called "long shaft" generator.
Similar?? except rigger reg
http://ytforums.ytmag.com/viewtopic.php?t=445047
