Re: removing fan on 400
Posted by CNKS on June 05, 2006 at 08:44:04 from (204.249.178.138):
In Reply to: Re: removing fan on 400 posted by budaa on June 05, 2006 at 02:34:23:
It's easier with it off. If it only needs packing, it will be much easier with the radiator removed. The pin will only come out one way. In your picture, remove the nut and pull up, You can't push it down because the diameter changes.
Today's Featured Article - Experimental Tractors Article - by Danny Bowes (Dsl). Tractor technology appears to have nearly hit it's pinnacle of development. If you agreed with the subtitle, you are rather mistaken. Quite, actually. As a matter of fact, some of the technology experimented with over 40 years ago makes today's tractor technology seem absolutely stale by comparison. Experimentation, from the most complex assembly to the most simple and mundane component, is as an integral a part of any farm tractor's development ... [Read Article]
