Hard starting IH B250
Posted by martin reece on June 05, 2006 at 17:47:04 from (209.5.56.25):
I have B-250 diesel that will only start if you use ether. It doesn't matter if you have run it for an hour and then shut it down. It will not start unless you give it a couple sniffs of ether. It dosn't smoke and seems to have lots of power. Is this a injector problem or maybe some other mechanical problem? Thanks for any input. Regards Martin.
