Re: I 184 tractor need info
Posted by Nat 2 on June 06, 2006 at 06:21:19 from (64.80.110.33):
In Reply to: I 184 tractor need info posted by heavyduty on June 05, 2006 at 19:33:03:
It would help if your question made sense. All I can tell is that you're trying to change the oil somewhere on your tractor, but where?
Here are answers to some common questions:
30 weight in the engine
Hy-Tran in the hydraulic reservoir and/or transmission.
I don't know if the 184 has a separate hydraulic reservoir or if it uses the transmission as a reservoir. You should get yourself a reproduction owner's manual that tells you all this stuff.
