Re: A/hyd
Posted by River Bottom Farmer on June 06, 2006 at 20:16:00 from (205.188.116.133):
In Reply to: A/hyd posted by Marty Johns on June 06, 2006 at 19:59:27:
Its not hard at all Marty although you can wrap up a considerable amount of money in it depending on what you are looking for as far as gpm and pressure.A simple belt driven pump and a reservoir are easily intalled and if done right they look real good as well as work good.If you are the mechanical type you can pick up the stuff at TSC and build it all yourself and there are alot of guys one here that can tell you what you need to get RBF
