Re: I 184 tractor need info
Posted by Fred Mills on June 07, 2006 at 05:35:37 from (69.95.252.108):
In Reply to: I 184 tractor need info posted by heavyduty on June 05, 2006 at 19:33:03:
Be sure to check the gear boxes on each wheel. There is a level check plug on the rear side of gear box. This is the rear axle housing. use hy-tran.
It is critical to grease the clutch release bearing carrier once per year or more. You will have to remove the frame cover to get to the zert.
Today's Featured Article - Pitfalls of Tractor Engine Rebuilds - by Chris Pratt. The first pop after you have put the machine together with your own hands is exciting and pleasing. The whole experience can be marred if one moves too fast and makes too many assumptions that they can just use "as is" some parts they should be closely scrutinizing and possibly attended to. In such cases, rework makes what could have been a fun project turn into an irritant or even a nightmare. Minor Irritants To give you an example of an minor but irritating proble ... [Read Article]
