Re: Farmall M, checking oil
Posted by Will Sick on June 07, 2006 at 21:16:39 from (207.177.50.175):
In Reply to: Farmall M, checking oil posted by Timmer81 on June 07, 2006 at 20:51:20:
There are two petcocks on the side of the oil pan. Oil level should be between the two. Capacity is 8 quarts. The hydraulic fill cap is beneath the gas tank. Remove te cap and if your lucky there is a dipstick. If not you can stick a clean wire down to make sure it at least has oil in the pump. It's not good to run the pump without oil. My M does not have a dipstick in the hydraulic filler so I just make sure it has a couple of inches of oil . Then if I'm using the pump I add enough oil to lift what ever. If you overfill the hydraulics oil will come out the filler when you drop an implement.
