Re: Best way to free up a stuck engine
Posted by Brian Schmidt on June 08, 2006 at 14:56:18 from (12.206.45.107):
In Reply to: Best way to free up a stuck engine posted by Walt In Ky on June 08, 2006 at 14:41:24:
If it is really stuck, you are going to have to pull the head anyway. The rings are probably bad enough anyway, that you will need to at least rering it. Pull the head and put about an inch of diesel in each bore and burn it. Then when it burns out place the xmsn in neutral and tap on the top of each piston with a wooden block as close to the bore size as possible. It will come loose eventually. Pull the pistons and hone the cylinders and check for pitting.
Today's Featured Article - Choosin, Mounting and Using a Bush Hog Type Mower - by Francis Robinson. Looking around at my new neighbors, most of whom are city raised and have recently acquired their first mini-farms of five to fifteen acres and also from reading questions ask at various discussion sites on the web it is frighteningly apparent that a great many guys (and a few gals) are learning by trial and error and mostly error how to use a very dangerous piece of farm equipment. It is also very apparent that these folks are getting a lot of very poor and often very dangerous advice fro ... [Read Article]
Latest Ad: 1997 cub cadet 7275 compact utility tractor 4wd hydro trans cracked block 3500 [More Ads]
