worn upper bolster/400
Posted by SDE on June 08, 2006 at 19:38:49 from (69.179.7.75):
Pulled the upper bolster out tonight. The thrust bearing was packed tight with mud. Hasn't moved in years. The shaft ,below the splines, should be 1.499 in diameter. At the worn spot it is 1.483. How or what is the repair for this? Turn it undersize and install a undersize bushing?
