Re: Best way to free up a stuck engine
Posted by markloff on June 08, 2006 at 21:58:01 from (70.41.84.208):
In Reply to: Best way to free up a stuck engine posted by Walt In Ky on June 08, 2006 at 14:41:24:
Hello, Do it right!!! Why waste you time with different blends of snake oil and the like. Pull the head and do it right. You want to look into the bores and valves anyway. This nonsense of rocking in road gear and 40, no dummy, 45 percent tranny fluid is all just different ways to wreck parts. Suppose that there is debris keeping the piston from reaching top dead center? The amount of force you put on the components is incredible if the piston is just 5-10 degrees from reaching top dead center and your reefing of the crank with a bar. Too many people take this ordeal as a personel vendetta to free an engine. I'll take the road less traveled. It has less bumps and ruts. You can pull the head, inspect everything and if the bores and pistons are good ,usually not, do a valve job and mill the head, slap the head back on with new gaskets and spend less than a few hundred bucks The reason most engines are locked is because they were put out to pasture for a reason, needing to be rebuilt. Why wreck the parts that may still be good? Usually the most expensive ones at that. Why the heck would turning the engine the opposite of normal rotation help any? If you knew which piston was stuck you want to free it on the downstoke. This could be clockwise or counter clockwise. My not so humble opinion. Mark
Home
| Forums
Today's Featured Article -
Identifying Tractor Noises - by Curtis Von Fange. Listening To Your Tractor : Part 3 - In this series we are continuing to learn the fine art of listening to our tractor in hopes of keeping it running longer. One particularly important facet is to hear and identify the particular noises that our
... [Read Article]
Latest Ad:
1997 cub cadet 7275 compact utility tractor 4wd hydro trans cracked block 3500
[More Ads]
Copyright © 1997-2024 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
