Re: 666 hydro update,
Posted by maplehillfrm,pat on June 09, 2006 at 19:42:02 from (170.215.213.31):
In Reply to: Re: 666 hydro update, posted by Allan In NE on June 06, 2006 at 10:55:06:
hello allen, I am not sure if this is too far down the list to see, but I got the foot n inch valve closed, and changedthe 2 capsules, no difference in operation, I took the side panel off on the left side , it has 6 bolts holding it on, I can see where the S R goes from forward to reverse with it off, On the inside of there it appears to be a plate that moves when the SR is moved, is this like a clutch plate sort of, because i see there are two pistons that appear to be able to ride on there , maybe if there is pressure applied from the other side, are these supposed to be loose until pressure applies to the plate? what next?? pat
