Re: Farmall Super M
Posted by magman on June 12, 2006 at 12:21:18 from (64.12.116.65):
In Reply to: Farmall Super M posted by Tom O on June 12, 2006 at 12:14:33:
I would try opening up the main fuel jet on the bottom a turn and try that. If not take the line of the carb and put an air gun to it and blow air as you turn the petcock on back into the tank. The little orfice that comes from the tank may be partially plugged not alowing enough fuel to get to the carb. Also have you checked the points for gap and make sure there good The plug gap also.
JUST A FEW THINGS TO CHECK
