Re: Farmall A governor adjustments
Posted by slydog on June 12, 2006 at 19:08:39 from (66.231.13.136):
In Reply to: Re: Farmall A governor adjustments posted by Red Dave on June 12, 2006 at 16:09:48:
Thanks for the info Red Dave but I have already tried that and that adjustment seems to be fine. I still don't have any throttle adjustments. It will idle on low throttle but as you put the throttle ahead one notch at a time the engine does not speed up until about the last 2 notches and then it speeds up to about half the throttle is should be and once in awhile it will surge at that speed. I did adjust that surge screw on the bottom of the governor and that did help the surge but still no throttle. Please help!!!
