Re: Farmall A 6 volt charging question
Posted by G Lee on June 13, 2006 at 19:20:58 from (71.147.18.192):
In Reply to: Re: Farmall A 6 volt charging question posted by El Toro on June 13, 2006 at 16:49:13:
Thanks for the reply. the meter does not change from idle to 3/4 or more. I will check out the web site. Gerald
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha ... [Read Article]
