Re: Farmall A 6 volt charging question
Posted by El Toro on June 13, 2006 at 16:49:13 from (205.188.116.133):
In Reply to: Farmall A 6 volt charging question posted by G Lee on June 13, 2006 at 15:56:59:
I don't think you will see much movement of the amp meter at an idle. How much does it move at 3/4 throttle? Put a volt meter across the battery terminals at 3/4 throttle and see if your volt meter is reading somewhere around 7.5 volts.
If you are getting this much charging voltage your generator and regulator are ok. Here's Bob M's troubleshooting procedure for generators and regulators just in case you need it. Hal
http://albums.photo.epson.com/j/Photo?u=4001561&a=30065733&p=63426275View
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha ... [Read Article]
