460 clutch question
Posted by marksd on June 13, 2006 at 20:32:00 from (71.38.28.208):
Hey guys, my 460 doesn't seem to shift gears all too well. You have to wait about 10 sec. afer you push the clutch in before you switch otherwise you just gring them til they slow down. From R to 1st is ok but upshifting just grinds them alot. I can down shift from 2nd to 1st ok most of the time also. When I first got the tractor I went by the book for adjusting the clutch and TA because I was trying to find out if the TA worked or not and it didn't. I am not sure if it shifted better before I adjusted it to spec. and don't remember how much I adjusted it.
So does any one have any idea wha way I can adjust the clutch to help it shift better?
