Re: 460 clutch question
Posted by Janicholson on June 14, 2006 at 08:17:32 from (199.17.6.122):
In Reply to: 460 clutch question posted by marksd on June 13, 2006 at 20:32:00:
The free play can be as little as 3/4" from the platform to the pedal stop (on the pedal). This is less than spec, but should provide enough travel to shift when fully depressed. If it does not, the driven disk may be stuck on the splines, or in worn spots on the splines, or the disk could be warped, causing it to drag.
JimN
