Goofy front tire
Posted by SGT K on June 14, 2006 at 06:39:14 from (216.125.213.242):
Check out this goofy front tire and rim. I ruined a tire while working, and found out my spare would not fit because the rim did not have enough off-set to clear the spindle. This was all I could find that would bolt up. I had to did a big hole because the jack wouldn't lift it high enough out in the field.
third party image
Now today I'm pricing new 11X16 front tubeless tires. $165.00 a piece for Firestones, around $120.00 for tube type. WOW! I can get these used 11X22.5 tubeless semi tires like in the photo for nothing. Other than the yellow John Deere paint, maybe this isn't such a goofy tire after all.
I don't think it would set too unlevel. You think those big tires would hurt anything?
Paul
Today's Featured Article - History of the Nuffield Tractor: Conclusion - by Anthony West. In the last piece I mentioned that Nuffield had reached the stage where they had chosen to drop the "Universal" from production. The two new models were given three figure numbers, instead of "three" and "four". Model numbers were introduced to help farmers and dealers instantly recognize the engine size and horsepower of the tractor, the 4/60 had a four cylinder diesel engine which developed 60 bhp at 2,000 rpm. The 3/42 had a 3 cylinder diesel engine which produced 42 bhp at 2,000 rpm. Th ... [Read Article]
