Re: Goofy front tire
Posted by Dr.EVIL on June 14, 2006 at 07:45:22 from (216.136.115.250):
In Reply to: Goofy front tire posted by SGT K on June 14, 2006 at 06:39:14:
I'm going to agree with BOB. If You have wheels and can get used truck tires for cheap or free I'd go that route. If You go with the 11.00 X 16's by ALL MEANS GO TUBE TYPE!!! When I bought tires for FARMALL back in the late 70's & early 80's that was the biggest complaint We got on tires was the fact We used tubeless fronts... They mounted easy since there were no tubes to pinch but once they got a little low on pressure or got enough weight on the front of the tractor and You turned sharp You rolled the beads off the wheels.
Today's Featured Article - History of the Nuffield Tractor: Conclusion - by Anthony West. In the last piece I mentioned that Nuffield had reached the stage where they had chosen to drop the "Universal" from production. The two new models were given three figure numbers, instead of "three" and "four". Model numbers were introduced to help farmers and dealers instantly recognize the engine size and horsepower of the tractor, the 4/60 had a four cylinder diesel engine which developed 60 bhp at 2,000 rpm. The 3/42 had a 3 cylinder diesel engine which produced 42 bhp at 2,000 rpm. Th ... [Read Article]
