M Flywheel Swap
Posted by Turbos10 on June 15, 2006 at 03:53:46 from (67.76.48.49):
Hey all,
I really need a steel flywheel on my M, so I am curious if I will have to split it. From what I have read, I found it is possible to change the clutch on an M by removing the belly pump. However, I am also wondering if the flywheel will come out the bottom as well.
I am also curious if any of you know an affordale source to get a steel flywheel.
Thanks,
Chris
