Re: H spun bearing
Posted by Janicholson on June 15, 2006 at 07:55:40 from (66.173.50.150):
In Reply to: H spun bearing posted by KansasBri on June 15, 2006 at 07:26:22:
The leak of antifreeze can destroy bearings. The crank must be measured with suitable micrometers in multiple directions acrocc the width of the surface to assure success in replacement. Those measurements will also dictate the correct insert to use if it is found to be OK (doubtful). The engine should be checked for cracks (especially the head to assure success in repair). Good luck, do it right or pay three times. JimN
