Re: starter ring gear removal
Posted by randy hall on June 15, 2006 at 18:50:41 from (209.11.236.16):
In Reply to: starter ring gear removal posted by CG Campbell on June 15, 2006 at 18:25:22:
you do not need to heat it, you need to just drive it off with a large punch and a good sized hammer.
