Re: Super A wiring
Posted by John T on June 16, 2006 at 06:15:39 from (66.244.90.5):
In Reply to: Super A wiring posted by Mark in Wa on June 15, 2006 at 22:45:29:
Mark, I can answer some of your questions theoretically but when it comes to the nuts n bolts point to point wiring connections you better trust Bob M over me. 1) You would be MUCH better off if you used a modern full fledged 3 or 4 wire Voltage Regulator over the older 2 wire simple Cutout Relay. The reason is with the older 2 wire cutout relay and the headlight switch field current control you only have 2 choices, being LOW charge and HIGH charge with no in between. You have to manually set the switch for low or high charge and it can happen you may either undercharge or overcharge (actually more harm to battery) the battery HOWEVER a full fledge VR does that automatically so you dont have to worry about where the light switch is set and does it by monitoring the battery and adjusts itslef accordingly. No fuss no worries. 2) I cant say sitting here (maybe Bob M can) if what you have is a Cutout Relay orrrrr a Voltage Regulator????? If under the cover theres ONLY ONE coil/relay its a Cutout Relay BUTTTTTTT if it has TWO coil/relays its a full fledged VR. A full fledged VR has terminals BAT ARM (or GEN) and FLD butttttttt I think IHC used some Cutout Relays that had the extra F terminal yet only one coil/relay inside i.e, a Cutout Relay and NOT a full fledged VR. EITHER a Cutout Relay or a VR still has at least a cutout relay inside it, its just that a VR also controls n regulates the gennys Field current automatically instead of it being done manually from where the light switch is set. 3) IFFFFFF its a VR (2 coil/relays inside) its F terminal wires to the gennys F post (NOT up to the light switch),,,,,,,its ARM (or GEN) terminal wires to the gennys ARM post,,,,,,,,,,,and its BAT terminal wires up to the load side of the ammeter. 4) IFFFFFFF its a Cutout Relay its BAT wires to ammeters load side,,,,,,,,its GEN (or ARM) wires to the gennys ARM post,,,,,,,,,,,and the gennys Field post wires up to the light switch. 5) If its a Cutout Relay where the gennys Field post wires to the light switch, those light switches have a resistor and the gennys Field is effectively wired dead to ground for high charge but to ground via that light switch resistor for low charge BUTTTTTTT some light switches have a resistor used for light dimming purposes so again, I cant say sitting here what light switch you have. I GUESS THE BIGGEST QUESTION that needs answered is if your device is actually a 3 wire VR (BAT GEN FLD) or a Cutout Relay (BAT GEN) but with the extra F terminal some IHC cutout relays had. If it has 2 coil/relays its a VR but if only one I believe (NO warranty) its a Cutout Relay in which case the gennys Field post wires to a light swiitch for field current control and charge regulation. Over the years and different vendors those cutout relays or VR's have changed appearance so I just cant be sure what you have UNLESS you look under its cover as described above, IFFFFF its a VR I would use it instead of letting the light switch regulate the charge in which case you NO LONGER wire the gennys Field post up to the light switch. Hope this helps and dont cornfuse ya John T
Home
| Forums
Today's Featured Article -
Hydraulic Basics - Part 2 - by Curtis Von Fange. In the last entry to this series we gave a brief overview of hydraulic system theory, its basic components and how it works. Now lets take a look at some general maintenance tips that will keep our system operating to its fullest potential. The two biggest enemies to a hydraulic system are dirt and water. Dirt can score the insides of cylinders, spool valves and pumps. Wate
... [Read Article]
Latest Ad:
[More Ads]
Copyright © 1997-2025 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
