Re: Cub 1948
Posted by old on June 16, 2006 at 15:51:43 from (4.245.5.167):
In Reply to: Cub 1948 posted by Lucien Cyr on June 16, 2006 at 15:42:22:
Might be your ignition switch, or coil. Is it a mag or a distubtor type system. If its a mag then its probably the coil but you need to do a little trouble shooting first. When it dies check to see if you have spark and what the spark looks like. It should be a nice blue spark. If you have spark you could also have a carb problem and its not getting fuel as it should be
