Re: F-30 rear wheel qestion?
Posted by SproutW on June 17, 2006 at 13:07:18 from (209.174.86.35):
In Reply to: F-30 rear wheel qestion? posted by Mopower on June 17, 2006 at 10:24:12:
Just so you know the rims for an F-20 and F-30 will not interchange. I"m familiar with the F-20"s and they had several different size tires available. 28 and 36 inch rims are the most common. Not to many came from the factory on rubber tires. Most farmers later on simply had the old steel cut down and a rim welded on the spokes. Much cheaper that way.
