IH distributor
Posted by RANDONF on June 17, 2006 at 19:36:57 from (66.42.87.210):
what do you guys generally time your distributors, with a 350 motor in a h... I set the initial timing at 16. then with the fly weights full open it got me 33 degrees. what do you think? also I am havng a prolem with an intermittant fly weight advancing? it has to e the spring as I built new studs on the weight plate and rebushed the weights. It worked like a champ on the ground but I think that the springs are shot, Who would you go to to get new springs and such
thanks for the advice in advance
Brandon
