Re: IH distributor
Posted by the tractor vet on June 18, 2006 at 08:17:39 from (66.202.111.228):
In Reply to: IH distributor posted by RANDONF on June 17, 2006 at 19:36:57:
Well as for me , when i work on a dist i am doing it on a dist strobe . This way i can see what the advance is doing at differant RPM's and makeing changes is not guess work . Also setting up a dist . for a working tractor and pulling tractor are not the same . Now with out getting into the books to see what is suppose to do thru out it's operating range the 16 degrees is a bit much and the 33 degrees on the top is to much for a field tractor. You will find that they will have better bottom end at around 27-30 degrees .
