Re: When did Cub go from 6 to 12V?
Posted by Redned on June 17, 2006 at 19:57:55 from (24.190.16.60):
In Reply to: When did Cub go from 6 to 12V? posted by 'nother cub owner on June 17, 2006 at 19:27:58:
All Cub tractors manufactured prior to serial number 224401, and Lo-Boys prior to serial number 18701 utilize a 6-volt POSITIVE ground electrical system, this was changed in mid 1964 to a more modern 12 volt negative ground system. The generator based charging system was replaced with an alternator at serial number 248125
This was taken off the ATIS site on Farmall cubs please check it out for useful cub information
Today's Featured Article - Experimental Tractors Article - by Danny Bowes (Dsl). Tractor technology appears to have nearly hit it's pinnacle of development. If you agreed with the subtitle, you are rather mistaken. Quite, actually. As a matter of fact, some of the technology experimented with over 40 years ago makes today's tractor technology seem absolutely stale by comparison. Experimentation, from the most complex assembly to the most simple and mundane component, is as an integral a part of any farm tractor's development ... [Read Article]
