Re: Farmall 230 engine rebuilding questions???
Posted by T.r.y. on June 18, 2006 at 02:59:01 from (64.12.116.65):
In Reply to: Re: Farmall 230 engine rebuilding questions??? posted by Shaggy on June 17, 2006 at 20:03:07:
ok well new super c engine kits increase to 3 1/4 and 340 330 are 3 1/4's. Not sure which one to go with? I think they should be the same sleeve setup being the same original block right?? where do you find hi-comp pistons?
