Re: 400 hydraulic uh oh --funny when it isn't you!
Posted by Farmall Frank on June 18, 2006 at 11:52:30 from (65.26.54.68):
In Reply to: 400 hydraulic uh oh --funny when it isn't you! posted by karl f on June 18, 2006 at 11:23:24:
Tell the IH guy to look for 361443R1, which is the Reservoir Top Cover Plate gasket.
If you're talking about the gasket under the Control Valve Column,that number is 361452R1.
I'd probably just make one if the IH guy can't come through.
Today's Featured Article - 12-Volt Conversions for 4-Cylinder Ford 2000 & 4000 Tractors - by Tommy Duvall. After two summers of having to park my old 1964 model 4000 gas 4 cyl. on a hill just in case the 6 volt system, for whatever reason, would not crank her, I decided to try the 12 volt conversion. After some research of convert or not, I decided to go ahead, the main reason being that this tractor was a working tractor, not a show tractor (yet). I did keep everything I replaced for the day I do want to restore her to showroom condition. ... [Read Article]
