Re: Super C won't Start
Posted by John T on June 18, 2006 at 19:03:41 from (66.244.90.5):
In Reply to: Super C won't Start posted by Scott Carter on June 18, 2006 at 17:26:48:
Scott, I would FIRST remove, clean n wire brush, and reattach each n every battery and starter and starter switch and cable AND ESPECIALLY the ground connection. If the ground is loose or corroded or carboned up, it can cause what you described. If the ground cable is to any thin or rusty piece of sheet metal, reattach it direct to a good frame type bolt for a better frame ground connection. That spark sounds like a loose or carboned connection to me, theres a good chance thats the culprit so remove n wire brush n clean n reattach n see what happnes. Once allllllll cables n connections n grounds n starter switch terminal are clean and tight and IF THE BATTERY IS OKAY??????, turn any lights on or attach a voltmeter or test lamp on the battery n try n start her. If the voltage drops drastically and/or any lights dim drastically, the starter could be bad or the engine stuck or the starter drive simply mechanically stuck, but if the voltage dont drop or any lights dim when you try n crank her, then I would suspect the starter switch if all else is okay. You sure the battery is okay and full charged??? maybe have a shop load test it or try a known good substitute battery. CHECK THAT FRAME GROUND CONNECTION AND GROUND CABLE TO BATTERY POST CONNECTION !!!!!!!!!!!! John T
Home
| Forums
Today's Featured Article -
Women and Tractors - Tractor Engine Repair - by Teri Burkholder. One of the great things about working on a tractor engine with your other half is that you know what he is thinking of at all times and can anticipate his every move and his next thought of what he will do. With Ben, anyway, I can tell! He'll be busy working and I’m handing him tools and he says, "give me that..." and I’ve already got it in his hand or "hand me that....."and I’ve got the portable light right where he needed it placed to see. "Run in the house and get me a...."as I open th
... [Read Article]
Latest Ad:
[More Ads]
Copyright © 1997-2025 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
