1066 PTO Pressure Check UPDATE
Posted by Michael Sheik on June 19, 2006 at 04:45:46 from (199.153.205.246):
Thanks Tractor Vet for the info last week. Called my Case IH mechanic buddy and he gave me his gauge and fitting setup to check the PTO clutch pressure. When I plumbed in and checked, it was running at 390 psi @ pto rpm. at idle it backed off 30 pounds and partial engage pressure was 42. I reset the high end to 285 and good to go. Glad I haven't use pto since replacing rubber boot on stem. Also glad I checked before I blew something out.
My buddy also is going to make a house call to set my clutch and TA so it will shift easy.
