Re: SM clutch adjustment
Posted by Andy Martin on June 19, 2006 at 06:48:33 from (64.219.39.195):
In Reply to: Re: SM clutch adjustment posted by dej(JED) on June 19, 2006 at 05:35:10:
It doesn't take much. If the fingers are adjusted right, and the pedal free travel is adjusted right, and the clutch won't release, there is probably something wrong with the clutch, like lining has come loose and is wedged against the flywheel. Pedal free travel takes all the slack out of the system and is the proper way to adjust the clutch.
You can change the clutch plate but not the pressure plate in a SM without splitting the tractor.
Have you messed with the pressure plate settings?
