Re: SM clutch adjustment
Posted by dej(JED) on June 19, 2006 at 07:06:06 from (66.212.151.134):
In Reply to: Re: SM clutch adjustment posted by Andy Martin on June 19, 2006 at 06:48:33:
No I haven't messed with the pressure plate fingers yet. When I got the tractor the clutch adjustment had the threaded rod under the clutch adjusted way in to where there is about an inch and a half of thread showing. I dropped the pump thinking there had to be something wrong. When I push in on the clutch, using a pipe wrench on the rod arm, there is very little pressure transfering to the fingers. Maybe I should have adjusted the clutch first.
