Re: Stuck engine idea is this crazy or could it wo
Posted by Brian Schmidt on June 19, 2006 at 19:41:24 from (12.206.45.107):
In Reply to: Stuck engine idea is this crazy or could it work? posted by River Bottom Farmer on June 19, 2006 at 18:35:02:
This is a good way to blow a head gasket or worse yet, crack the head. I wouldn't try it. If you go to all that work, you might as well pull the head. Another few bucks for a head gasket, no big deal. You will spend than in grease and time.
If it is stuck that bad, the least you should do is hone it. You may have to replace liners and or rings and pistons. If not, it will smoke like a banshee.
