Re: Stuck engine idea is this crazy or could it wo
Posted by Dan in Ore on June 20, 2006 at 02:52:59 from (12.108.20.240):
In Reply to: Stuck engine idea is this crazy or could it work? posted by River Bottom Farmer on June 19, 2006 at 18:35:02:
If you use that method, make sure the piston is not at bottom dead center or you will bend/break a crankshaft, rod or piston. Good luck.
Dan
