Re: steering problem MAYBE???
Posted by the tractor vet on June 21, 2006 at 19:00:57 from (64.179.117.145):
In Reply to: steering problem MAYBE??? posted by danny waters on June 21, 2006 at 18:38:25:
Well your hitch pump has nothing to do with your problem . If any pump is bad it is the MCV pump . But before ya start tearing things apart there are things to check first . you could have a sticking flow divider broken pressure reg. spring blowen o/rings , blown MCV gskt. or low pump volume . Does your oil tel-tale lite work in the dash??? if not fix it . Now if you are not a real good mechanic then getting into the MCV is not for you as things have to be to spec. and ya need some special hyd. fittings and a good hyd pressure gauge , also a flowrater is a real big help . So to save time and money best to take it to a real good mechanic on this one you will be money ahead. Now if you were close i would have no problem checking it out.
Today's Featured Article - On the Road with Dave Gohl: Tractors and Farming - by Dave Gohl. I never thought I'd live to see the day, when I could call myself a farmer. What allows me to say this? Well, when our family moved to our 20 acre site near New Prague, Minnesota, I had one thought in mind. You guessed it, farm it somehow. A little history is in order. In my younger days, mom, dad and my brother made frequent visits to dad's youngest brother Pete, who took over the home farm from grandpa MIke. It was the typical set-up, milk cows, pigs & chickens. In the winter, we'd play ... [Read Article]
