Re: steering problem MAYBE???
Posted by the tractor vet on June 21, 2006 at 19:38:22 from (64.179.117.145):
In Reply to: Re: steering problem MAYBE??? posted by danny waters on June 21, 2006 at 19:06:09:
It takes hdy pressure from the MCV pump and that pump is located in the center section behind the thick cast valve body down on the left in ft. of the step . Now if your feeling froggy then get and I T manual as it lists all the spring lenghts and test pressures for each and every spring in there and where all the spriongs and valves go and just what they do . But you will not be able to flow rate the pump as this takes special equipment vary few of us barnyard tractor mechaincs have flow raters as it is one of them high priced toys that ya would love to have if ya had and extra 3750 bucks for and older rebuilt one and the brand new ones would get ya a realy nice pickup . I would love to have one of the new digital high volume high pressure ones with the anilizer so i could do the newer PFC systems . But anyhow back to your problem it is one of many things that could be causing it to not move . IT will also stop dead in it's tracks if ya crowed the steering one way and step on the brakes . And the list i gave ya is just a real quick list off the top of my head and like i said it would even take me a bit to find the problem . Now it also could be that it is dumping pressure in the T/A it's self and when ya crowed the steering it is loosen the rest of the lock up pressure and there for it stops . The T/A has to have pressure to lock up the clutch packs , Now also the low side may be on it's way to lunch also . Ya need atleast 235 LBS of lock up pressure myself i like it to be up around 265 on a 706 and higher on the higher HP tractors.
