Re: Cub ground
Posted by John T on June 22, 2006 at 08:59:46 from (66.244.90.5):
In Reply to: Re: Cub ground posted by souNdguy on June 22, 2006 at 07:24:31:
Fun discussion (for us lectricity dudes at least lol). I see your point, but dont see all that much difference in coil winding line losses where the primary resistance is maybe only 1.5 to 3 ohms (of larger wire) versus several thousand ohms or much smaller wire in the secondary. Still, its resistive heat loss and I agree a coil is less efficient and may run a tad warmer if wired in reverse (but still sparks of course).
Let me toss out an idea to get your opinion !!
Do you agree ???????
IFFFFFFF the coil is wired in the correct polarity, doesnt the secondary electron flow then take place FROM the hotter electrode tip TO the cooler ground strap BUTTTTTT if its wired in reverse,,,,, thennnnnn the electron flow is in the less efficient direction FROM the cooler strap TO the hotter electrode tip andddddddddd thats a reason why the spark has more energy (volts x amps x time energy discharge across the gap) if the coil is wired correct!!!!!! I think the figure I read or heard was that the coil voltage has to raise like 4k volts higher to arc current across the gap if wired in reverse then if wired correct. I.E. DOES the secondary arcing current flow in the opposite direction across the plugs gap if the coil is wired in reverse???? Im pretty sure it does and to tell one could place a lead pencil tip in say a 1/4 inch gap between the plug wire end and the plug and actually physically observe the direction the lil carbon sparks move, TO OR AWAY from the plug. Im fairly certain ifffff the coils wired correct the electrons which have a mass are gonna cause lil carbon sparks to move towards the plug iFFFFFFF the coil is wired correct but in the opposite direction if its wired reverse.
Soooooo what ya think?? Agree???
John T (been the late sixties since I studied this at Purdue in EE so Im a tad rusty lol)
