Re: Cub ground
Posted by souNdguy on June 22, 2006 at 07:24:31 from (12.65.132.22):
In Reply to: Re: Cub ground posted by John T on June 22, 2006 at 07:01:16:
Yep.. the plugs fire better as you surmise, for the same reason a tube works..
And the coil, since they are a dc induction coil, and the secondary is tied to one of the primary sides of the coil.. hooking it up in it's correct orientation makes a difference in how much copepr the electrons have to fire thru.. Hooking up 'backwards' adds the primary winding tot the path... no biggie.. still works.. but can reduce spark intensity parasitically
Soundguy
