Re: H – Brakes – Wet or Dry?
Posted by Steven@ND on June 23, 2006 at 05:33:54 from (72.20.78.220):
In Reply to: H – Brakes – Wet or Dry? posted by ChrisL on June 23, 2006 at 05:22:55:
The brakes on your H are dry. There is a seal behind the drum.
If there is oil behind the cover, you need to fix the seal.
