Re: H – Brakes – Wet or Dry?
Posted by CNKS on June 23, 2006 at 05:54:40 from (204.249.178.138):
In Reply to: H – Brakes – Wet or Dry? posted by ChrisL on June 23, 2006 at 05:22:55:
To add to what Steven said, the seal is above the static oil level, you do not need to drain any oil.
