Re: Hey Allan - Too high of oil pressure?
Posted by Allan In NE on June 23, 2006 at 08:03:22 from (148.78.243.24):
In Reply to: Hey Allan - Too high of oil pressure? posted by Jay (ND) on June 23, 2006 at 07:16:25:
Jay,
Sounds like it is a symptom of a very healthy engine to me. Every tractor I've ever had "pegs the gauge and stays there".
If you're worried about it, I'd put a mechanical gauge on it to see what is really going on. I wouldn't worry about it unless it is up over around 80 psi. Most gassers normally run in at 60 and the diesels 75-80 lbs.
I've always set up LP irrigation engines with industrial bearings at 80 lbs also when using Murphy switches. However, get any higher and you can start to see signs of "washing" at the babbit.
Good luck with your project,
Allan
Today's Featured Article - Experimental Tractors Article - by Danny Bowes (Dsl). Tractor technology appears to have nearly hit it's pinnacle of development. If you agreed with the subtitle, you are rather mistaken. Quite, actually. As a matter of fact, some of the technology experimented with over 40 years ago makes today's tractor technology seem absolutely stale by comparison. Experimentation, from the most complex assembly to the most simple and mundane component, is as an integral a part of any farm tractor's development ... [Read Article]
