Re: Hey Allan - Too high of oil pressure?
Posted by justin w on June 24, 2006 at 10:22:44 from (24.241.234.32):
In Reply to: Re: Hey Allan - Too high of oil pressure? posted by Allan In NE on June 23, 2006 at 08:03:22:
for the IH tractors of the 40s/50s, the oil pressures should be:
A,B,C,H,M,etc Gas: 70-75psi
Diesels: 45psi
Cub: 30-35psi
Any tractor that loses a fair amount of oil pressure after warming up, has a serious problem with oil clearances, and should be repaired before some major damage occurs. After an engine rebuild which includes a reground crank W/bearings, Camshaft bearings, Block cleaning, new oil pressure regulating spring and valve, none of my engines will lose pressure when warm. I also use the oil that IH specifies, 30W Low Ash oil.
