Re: 966 Slow Hydraulics and 3 Point UPDATE!!
Posted by JJK on June 23, 2006 at 20:06:40 from (216.189.131.36):
In Reply to: 966 Slow Hydraulics and 3 Point UPDATE!! posted by Erik in WI on June 23, 2006 at 19:36:32:
There is one o-ring in the cover that will sometimes blow out. As you look at the cover, the top comes to a point somewhat, and that is where the o-ring is located. The only other o-rings are under the hyd pump and spacer block that are bolted to the cover. I didn't see your old post so I don't know whats been said or done. Do you know that the hyd pump is good? Did this happen all of a sudden or gradually getting slow? If you find that you need a new pump and would like more gpm's for some reason there is a 15 or 17(can't remember which it is off hand) gpm pump available but I would recomend putting in the tephlon o-ring in the cover because that will hold up better.
