Re: 966 Slow Hydraulics and 3 Point UPDATE!!
Posted by K.B.-826 on June 23, 2006 at 20:35:27 from (24.180.143.24):
In Reply to: 966 Slow Hydraulics and 3 Point UPDATE!! posted by Erik in WI on June 23, 2006 at 19:36:32:
Have you replaced the relief valve? Filter new? You could have an internal leak. Remove the top link bracket, start the engine, and see if there"s a large amount of oil spraying down from the rockshaft housing. If you do decide to pull the pump yourself, here"s a tip for reinstalling it- there"s a short tube between the pump and the filter housing. Leave it out, install the pump, and then install the tube into the pump through the filter housing. If you try to install the tube with the pump, you run a good risk of damaging the seal that seals off the filter housing from the transmission case, which will possibly cause an air leak, and will definetly cause a huge oil leak the next time you remove the filter cover.
