Re: H 4 terminal reg install
Posted by John T on June 24, 2006 at 05:29:32 from (66.244.90.5):
In Reply to: Re: H 4 terminal reg install posted by Brownie 45 on June 24, 2006 at 03:37:04:
Brownie, that makes sense. If loads are more direct connected to the VR (the L terminal) versus their current having to pass through the cutout relay, some of the gennys output current can go direct to the load and the only amount having to pass through the cutout relay to charge the battery is whats really needed, thereby they could regulate a bit more precisely and NOT overcharge the batery like could happen with a 3 pole VR when the lights are on which puts them in more of the max charge state. I need to get and study an internal 4 pole VR wiring diagram then we can settle this matter
Fun discussion, yall take care n God Bless
John T
