Re: H 4 terminal reg install
Posted by Brownie 45 on June 24, 2006 at 03:37:04 from (207.177.82.234):
In Reply to: H 4 terminal reg install posted by 55 50 on June 23, 2006 at 16:53:58:
I understood that the L terminal gave a quicker response[ immediate] to a load that was placed on the system. I believe that it is connected to & draws current from a winding in the voltage regulator relay in the regulator itself. The more current that is drawn, the less the relay pulls the contact & hence more output from the generator. Hope some of this makes sense.
